I just replaced the secondary water valve in my Amana side by side due to no water to ice maker. This solved that issue but now I have an even bigger issue. Anytime the ice maker fill valve opens, water is also despensed through the front door water/ice dispenser and all over the floor. The water dispenser works normally when getting water through the door. I have checked the wiring to both the primary and secondary water valves and do have yellow/white wires to water valve and tan/white to ice maker inlet valve. What would cause this?
Also I have changed the water filter and purged all the air out of lines but I am unable to reset the filter light (by pressing the refig door switch 5 times in 10 seconds) but the light stays red. Are these two issues related?
Thanks for any help. Thom
