hughqv
#1 Posted : Monday, May 27, 2013 7:55:39 PM(UTC)
hughqv
My whirlpool plus gold fridge compressor and fans do not work. But the lights come on. I replace the compressor relay and capacitor. I have tested the thermostat and door switch and its good. Any ideas. Thanks
#2 Posted : Tuesday, May 28, 2013 1:39:01 AM(UTC)
Parts for Whirlpool GD5SHAXKQ00 Refrigerator - AppliancePartsPros.com
Sounds like a defrost board problem.
You could check for 120 volts at the board (BK to WH). (Input power)
If OK then OR to WH (thermostat/compressor power)
File Attachment(s):
GD5SH.pdf (544kb) downloaded 10 time(s).
