Drier has power, light turn on when door is opened. Checker the breaker box anyway...All good. Timers appear to be working and Start clicks after Timer is cycled. Thermo fuse has continuity. Checked all connection and cleaned machine as I went. Nothing happen...
Thanks in advance,
Wild Bill Tex :confused:
You seem to be missing the first three digits of the model number. Sears/Kenmore numbers are usually 3 numbers, a period and then an additional 8 numbers. |
THIS FORUM IS DEAD!!!!!!! |
