Whirlpool washer leaks water on the floor at bottom,front center of machine when filling tub with water (cold and hot). Appears to be dripping or running down inside the front panel of machine. This started after I had machine on it's back to replace the clutch assembly.
Take off the cabinet and start up the machine. You should be able to see where the leak is coming from. My guess is that you may have dislodged the pressure switch tube., but watching it while it fills or empties should locate the problem.
Originally Posted by: sidfink43  Take off the cabinet and start up the machine. You should be able to see where the leak is coming from. My guess is that you may have dislodged the pressure switch tube., but watching it while it fills or empties should locate the problem. Check the splash guard to be sure it is in place, and is not causing splash back from the water inlet.
