bell8116
#1 Posted : Thursday, May 23, 2013 10:06:32 AM(UTC)
bell8116
When turned on would make a loud buzzing noise. Turn off &back on workrd fine. Now will only come on and make buzzing sound, no heat.
Simon / APP Team
#2 Posted : Thursday, May 23, 2013 12:10:47 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely there is shorted diode or grounded magnetron.
Use the multimeter to run continuity test.
Before handling the diode properly discharge the hi-voltage capacitor.
If diode shows continuity-replace it. If the magnetron filament contacts shows continuity to the body-replace the magnetron.
You actually may replace both the, price of the diode is only few dollars.
Part number: WB27X1160
Part number: WB27X10017
Here are the breakdown diagram and 01-Microwave parts for GE JVM1660WB005 - AppliancePartsPros.com
Post the results.
Simon.
GE Profile Micro wave humming, no heat. Magentron? Part #? (Microwave Repair)
by DeltaDave 6/22/2012 9:02:57 AM(UTC)
