solarhome
#1 Posted : Thursday, April 23, 2009 4:14:05 AM(UTC)
solarhome
The right rear burner was not igniting, so I replaced the igniter. Then the igniting was sporadic on different burners so I replaced the spark module. Now the left two burners ignite but not the right two. The left two ignite (but not light) when any of the knobs are turned, but the right two don't ignite at all. What's my next move? Thanks.
#2 Posted : Thursday, April 23, 2009 7:43:52 PM(UTC)
The first thing I would do is double check all wires and connections to the spark module. If there is nothing wrong then replace the ignition switches wiring harness assembly.
- The part number for the wiring harness assembly is AP3215934
Here are the breakdown diagrams and Replacement parts for FRG FGFL77ASF | AppliancePartsPros.com
