u71589
#1 Posted : Wednesday, May 22, 2013 12:27:05 PM(UTC)
u71589
I went to start my dryer this morning and it did nothing. There is power at the cord, dryer light is not on and timer is not working. Please HELP!! :)
Simon / APP Team
#2 Posted : Wednesday, May 22, 2013 1:34:04 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
You need to find out if there is 230VAC at the wall outlet. Use a multimeter and be careful - it's 230V. If there is no proper voltage try to reset the breakers.
If the voltage is present check the door switch for continuity (C to NO, C to NC).
The door switch Part number: 3406107
Here are the breakdown diagrams and Cabinet / Literature parts for Whirlpool LER5600JT0 - AppliancePartsPros.com
Post the results.
Simon.
u71589
#3 Posted : Wednesday, May 22, 2013 1:58:46 PM(UTC)
u71589
I will try this when I get home.
u71589
#4 Posted : Sunday, June 2, 2013 6:18:43 AM(UTC)
u71589
It worked perfect. Thanks for your help!
Simon / APP Team
#5 Posted : Monday, June 3, 2013 5:17:19 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
So what was it? The circuit breaker?
Simon.
Kenmore Stackable Washer and Dryer has no power (Washer Repair)
by jimmyphatz 1/17/2015 10:50:08 AM(UTC)
Dryer has no power (Dryer Repair)
by deerslayer641 11/2/2010 4:51:30 PM(UTC)
by fperez9t3ta 2/18/2009 1:42:51 PM(UTC)
