After 24 hours turned off (unplugged), I plug it to the outlet then it Works some time, about 1~6 hours, then unit compressor doesn't turn on again and front door panel (1 digit kind) seems hang (doesnt respond to any button press). If shortly after that, it is unplugged and plugged again, front door panel shows the 8 number with all LEDs on, and alarm keeps beeping and unit compressor doesnt start. Images/Photos: https://www.icloud.com/photostream/#A5JtdOXmGnwJhE
Hello,
The model number you posted does not come up. Verify and repost it please.
Was it made to use in US?
This refrigerator made to use out of US. Unfortunately GE does not provide any technical information for such products.
Thanks for your reply, Mr. Gene.
