curttrout
#1 Posted : Monday, May 20, 2013 2:43:07 PM(UTC)
curttrout
the dryer keeps spinng when everything shows off. i have to unplug it. i have the door switch disconnected and it still keeps spinng :(
Simon / APP Team
#2 Posted : Monday, May 20, 2013 4:12:09 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the motor relay contacts are welded shot and you need a new relay.
The motor relay Part number: W10133335
You may check it with a continuity test or just remove one power wire off the relay (unplug the unit when disconnecting the wire).
Here are the breakdown diagrams and 07-Cabinet, Relays (ESE9900 & ESG9900) parts for Maytag ESG9900 - AppliancePartsPros.com
Post the results.
Simon.
