john simmons
#1 Posted : Saturday, May 18, 2013 5:10:26 AM(UTC)
john simmons
Ice dispenser quit working.Installed new motor part #2323603 Did not fix the problem. I am reluctant to apply 120vac to motor like someone suggested because the label says 120 vdc rectified. I dont know if the rectifier is in the motor housing or somewhere else.The ice door opens when the pad is pushed.I need to know how to get to the switch for the motor if it is separate from ice door sw. Could be control module I suppose.I need to know how to ck it out and location.
john simmons
#2 Posted : Saturday, May 18, 2013 7:14:10 AM(UTC)
john simmons
OK I checked voltage at dispenser motor and got 70 volts DC.
What does this indicate the problem could be?
Water/Ice dispenser not working... (Refrigerator & Freezer Repair)
by CartmanMTB 1/31/2011 2:05:25 PM(UTC)
Ice dispenser not working. (Refrigerator & Freezer Repair)
by Howard Sadoski 11/17/2010 6:18:13 AM(UTC)
GE mainboard replaced, now water/ice dispenser not working. (Refrigerator & Freezer Repair)
by TravisR 4/2/2010 9:27:59 PM(UTC)
