jhf1
#1 Posted : Monday, May 13, 2013 11:40:03 AM(UTC)
jhf1
My side by side defrost cycle will only start if I advance the timer manually. I have already replaced the timer and the bimetal def. Defrost works fine once it starts. When I replaced the timer it started to defrost right away, but will not cycle on its own.
#2 Posted : Monday, May 13, 2013 5:59:19 PM(UTC)
What is the part number of the defrost timer you installed?
How did you connect the new defrost timer?
jhf1
#3 Posted : Thursday, May 16, 2013 7:29:55 AM(UTC)
jhf1
i installed part 482493 and connected timer motor lead to terminal 2. Should I move it to terminal 1?
#4 Posted : Thursday, May 16, 2013 12:54:22 PM(UTC)
You hooked up the new timer wrong. That's why it did not work.
The new timer comes with the installation instructions (attached to the post). Per the original timer connections you have a continuous run timer application what means it has to be hooked up as instructed in Procedure 1. The timer motor lead should be connected to terminal 1.
File Attachment(s):
jhf1
#5 Posted : Thursday, May 16, 2013 2:10:39 PM(UTC)
jhf1
I switched the lead to terminal 1. I can hear the timer running all of the time now. Sounds like the issue is solved. Thanks for the tip Gene! much appreciated.
#6 Posted : Thursday, May 16, 2013 2:24:03 PM(UTC)
You are welcome. I'm glad it's up and running.
jhf1
#7 Posted : Friday, May 17, 2013 7:26:28 AM(UTC)
jhf1
If you put your ear to the reassembled control panel and listen carefully you can hear the timer running.
#8 Posted : Friday, May 17, 2013 12:46:15 PM(UTC)
That is correct.
Whirlpool WRF989SDAW02 36 inch Side by Side Not defrosting (Refrigerator & Freezer Repair)
by viking59 2/1/2019 3:51:16 AM(UTC)
kenmore side by side not defrosting (Refrigerator & Freezer Repair)
by john 10512 6/3/2014 9:36:51 AM(UTC)
GE side by side Not defrosting (Refrigerator & Freezer Repair)
by TOPGLOCK 3/19/2012 3:24:36 PM(UTC)
jennair side by side not defrosting (Refrigerator & Freezer Repair)
by Tammi Card 8/15/2011 4:13:45 PM(UTC)
maytag side by side not defrosting (Refrigerator & Freezer Repair)
by adamerik 4/9/2010 11:49:35 AM(UTC)
Side by Side not defrosting (Refrigerator & Freezer Repair)
by pettinej 11/10/2008 3:01:19 PM(UTC)
Amana side by side not defrosting (Refrigerator & Freezer Repair)
by eriksena 7/18/2008 7:23:09 PM(UTC)
