AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer fills but doesn't agitate, drain, spin, rinse
Washer fills to whichever level I select. That's where it stops. It won't agitate, drain, spin, rinse. The timer doesn't advance or move. I hear no motor running. I have changed the lid switch and the timer. No change. What next?
Groups: APP Team
Hi. What you should do is to check the water level switch. With tub full the contacts V and T must be closed. You may run a continuity test or install a temporary jumper wire (first unplug the washer) between V and T. The water level Part number: w10335056
Post the results. Simon.
Groups: Expert
Check the wiring harness connector at the motor. Look for broken wire, burned wire, corrosion...etc. Unplug washer, check continuity between power plug neutral (wide blade) and the white wire at the motor and the white/black wire. Should read 0 ohms (short). A faulty water level switch would prevent it from agitating but not from draining/spinning if you have tried advancing timer manually to drain/spin.
Eric
Washer Repair
