Lock Lite is lit on lower drawer, will not start
It should tell you haow to unlock it in your operators manual.
If not try unplugging the unit for a couple minutes to see if it will reset.
If it is hard wired in flip the circuit breaker off. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) It should tell you haow to unlock it in your operators manual.
If it is hard wired in flip the circuit breaker off. I was abel to fix it! It was the control module, this is a two drawer unit and most of the parts are on / in the drawer itself. I open both drawer face's and with a little part swapping I was abele to fine the bad part in 30 min. I had call a good repair guy that I hade uesd many times over the years and he told me he would not touch this type of two drawer dishwasher, and that the designers of these type of units should all be lined up and shot in the head. and then he walked out. Thanks to Appliance Parts Pros. I did it my self for $130.00!
