KWendle
#1 Posted : Monday, May 13, 2013 3:52:35 PM(UTC)
KWendle
I just bought this range used, and the convection does not work. I read the instructions for testing. Can you tell me which wires to test, and how to get to the motor to test it? (Inside front oven access, or rear access?)
Simon / APP Team
#2 Posted : Monday, May 13, 2013 4:47:02 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The access to the convection motor is from the rear. Disconnect the plug at the motor and check (with oven turned on) if there is 120VAC at the plug. If the correct voltage is present - replace the motor
Part number: 74004947
Post the results.
Simon.
Guest (4)
