tannerthehammer
#1 Posted : Saturday, May 11, 2013 11:20:13 AM(UTC)
tannerthehammer
There aren't any bolts to remove the freezer door gasket so I'm not sure how to get it off. Any ideas?
Brand: Whirpool (fridge)
Model: ER8MHKXRS 03
Thanks!
#2 Posted : Sunday, May 12, 2013 5:46:31 AM(UTC)
The following may help.
It will probably have screws under the gasket or it will fit into a slot in the door. I think yours is the latter.
The below should help
http://www.applianceaid.com/refrigerator-door-repair.php#gasket
tannerthehammer
#3 Posted : Sunday, May 12, 2013 5:51:22 AM(UTC)
tannerthehammer
Thanks for responding...I figured out that it wasnt the gasket but I needed to shim the door hinge as it was hanging a bit low and rubbing so I went and got a couple 13 cent 3/8 washers and it works great now...
