jmcclintock
#1 Posted : Wednesday, May 8, 2013 5:25:37 PM(UTC)
jmcclintock
I "inherited" a kitchen aid oven without a wall plug. I used my old Jenn Air 3 prong wall plug. Burners work, clock works and that is it. Is it my wall plug? do I need a 4 prong? the code F5 E3 comes up after reset the breaker.
Please help!
#2 Posted : Thursday, May 9, 2013 2:43:15 AM(UTC)
Parts for Whirlpool KESC307BWH9 Range - AppliancePartsPros.com
Here is the install sheet
https://www.whirlpool.com/digita...ctions%20-%209752043.pdf
And just in case you do not have it the operators manual.
https://www.whirlpool.com/digita...0Guide%20-%209752957.pdf
[COLOR="Blue"]Is it my wall plug?[/COLOR]
could be you will have to check it.
[COLOR="Blue"] do I need a 4 prong?[/COLOR]
Depends how it was hooked up originally.
On 4 wire Neutral and ground are separate.
On 3 wide Neutral and ground are the same. Ground (frame) is usually tied to the Neutral in the unit with a ground strap.
See the install sheet.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
File Attachment(s):
KECS307.pdf (142kb) downloaded 3 time(s).
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 11/26/2022 8:40:21 AM(UTC)
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 10/16/2021 7:56:35 AM(UTC)
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 9/6/2021 9:36:45 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 3/18/2020 3:28:11 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 3/20/2019 7:54:34 AM(UTC)
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
