tgamble
#1 Posted : Wednesday, May 8, 2013 8:02:48 PM(UTC)
tgamble
Last weekend the fridge stopped cooling. All lights work and there's power, just no cooling. Fans are working as well.
For about a year we had been hearing it "clunk" every 30 minutes or so. Was told that this model had issues with the compressor brackets?
I'd like to fix it vs. replace so any help would be appreciated.
#2 Posted : Thursday, May 9, 2013 12:35:48 AM(UTC)
Check the compressor in the back, if hot and vibrating, you have refrigeration problems, if cold, check the back of the motherboard, probably has bad solder joints, available here WR55X10942
