kwiknuts
#1 Posted : Wednesday, May 8, 2013 8:26:51 AM(UTC)
kwiknuts
water leaks or splashes where fill tube meets icemaker and freezes below that areain ice bin
Ok , my older Maytag side by side icemaker needs a repair. water leaks or splashes where fill tube meets icemaker and freezes into a clump right below that area. Have de-thawed it 2 times and it happens again and again. looked as best I could at fill tube it seems ok and not cracked but I cant really see the end of it where it meets the fill cup but during this problem when I squeeze the fill tube it seems like its clogged somewhat with frozen water.
During this time the icemaker makes ice just fine but then eventually stops because the bar wont go all the way down as its hitting the frozen lump of ice thats forming slowly each day.
I was able to watch a fill cycle and put my hand near where tube meets fil cup and I felt water splashing from that area thus causing this clump of ice formation.
From what I have researched here in other posts I may need a new fill valve and possibly a new fill tube ? If so what part # exactly will I need for each? and is the fill valve the most likely culprit ?
thanks
Mark
Simon / APP Team
#2 Posted : Wednesday, May 8, 2013 3:02:20 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Mark.
What most likely happens is that the fill tube is too close to the icemaker fill cup wall. Remove the icemaker, clean the fill cup from ice and use the sharp knife to shorten the fill tube by a 1/4". That should help.
Post the results.
Simon.
kwiknuts
#3 Posted : Wednesday, May 8, 2013 4:43:05 PM(UTC)
kwiknuts
Simon what would cause the tube to grow in length over these years? Everything was fine till a few months ago? I have not changed a thing on ice maker or fill tube or for that matter anything on the icemaker. Maybe our water pressure changed higher? Sure would like to know its just the tube length and not the fill valve. Maybe the tube shifted somewhat over time and it does need a trimming like you said.
Mark
