handyjohn
#1 Posted : Tuesday, May 7, 2013 8:45:52 AM(UTC)
handyjohn
Washer wont drain. Will fill and will agitate. Then stops before drain.
Tried all timer settings. Water in tub. No buzzing sound at motor. Timer does not advance to off so timer dead stop before drain.
LID switch (electrical?)? Pressed down with screwdriver already.
fairbank56
#2 Posted : Tuesday, May 7, 2013 10:50:53 AM(UTC)
fairbank56
Groups: Expert
Sounds like the lid switch. Unplug washer, unplug the two wires from the switch and jump them together for test.
Eric
fairbank56
#3 Posted : Tuesday, May 7, 2013 2:48:24 PM(UTC)
fairbank56
Groups: Expert
Sorry, I was looking at the wrong parts diagram (version 0 vice version 1 of your model). Your lid switch is different. You can open the control panel and unplug it there on the right side and jump the wires (the two going to the timer), disregard the green wire.
Eric
Guest (4)
Whirlpool washer wont drain or spin (Washer Repair)
by nancyelaine 2/15/2017 7:59:14 PM(UTC)
whirlpool washer wont drain out (Washer Repair)
by amyholtkamp@yahoo.com 12/12/2009 1:28:04 PM(UTC)
