Vinceaim
#1 Posted : Thursday, May 2, 2013 3:13:31 AM(UTC)
Vinceaim
My upper and lower electronic light switches became inoperable after I grounded a light socket. Is there a reset or fuse to correct this problem?
#2 Posted : Friday, May 3, 2013 3:10:47 AM(UTC)
Nothing comes up using the given model number.
Please check it.
Are you sure that the 2 is a 2 and not a S.
In any case on most units there is not a fuse for the lights.
It sounds like the lights are controlled through the control board and it's electronics would blow before a fuse could.
Unfortunately it sounds like that part of the control board is toast.
Vinceaim
#3 Posted : Saturday, May 4, 2013 11:19:56 AM(UTC)
Vinceaim
Yes, it's a2. What's the number of the control board to replace?
#4 Posted : Saturday, May 4, 2013 5:36:00 PM(UTC)
Sorry but I cannot find any tech info on the model since your original number is correct.
I would not recommend replacing the board until you can see how it is wired.
Vinceaim
#5 Posted : Sunday, May 5, 2013 12:16:44 PM(UTC)
Vinceaim
It might be listed as cpd 230
#6 Posted : Tuesday, May 7, 2013 1:53:17 AM(UTC)
Sorry still no joy.
All I can suggest is tat you try contacting Dacor or a Dacor dealer.
Dacor oven lights (Oven Repair (including Ranges and Cooktops))
by Elizabeth Siefker 12/23/2007 6:49:11 AM(UTC)
