My ice maker makes ice but will not dispense. When the paddle is pushed the light comes on and the door under the ice maker opens up but no ice comes out.
Groups: APP Team
Hi. Most common problem would be bad dispenser motor. To get access to it open the freezer door and remove the cover plate located in the center of the door. Use the attached link for the test instructions. Simon. Here are the breakdown diagrams and http://www.appliancepartspros.c...el.aspx?model_id=5138093
Replaced micro switch on door and motor still nothing, when I put the motor in I pluged it in put did not install it,just let it. Sit on the door.
I do not have power going to motor
Groups: APP Team
Hi.
Please provide the complete model number of the unit and a bit more details on what the problem is.
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi.
Simon. Model # GD5DHAXVA07 I, do not have voltage 120V DC going to the dispenser, no voltage.
