Eyemalive
#1 Posted : Saturday, May 4, 2013 10:23:54 AM(UTC)
Eyemalive
I replaced the Drum Glides, however when I put it all back together, it seems like the drum is fairly tight or shall I say too tight. It turns, but takes effort.
If I leave the front bulkhead off and turn the drum, it is rotating freely.
There was adhesive tape that was under the original glides, which I left on and wonder if I should have removed it.
Any suggestions?
scott5495
#2 Posted : Saturday, May 4, 2013 2:50:56 PM(UTC)
scott5495
make sure the tub is in place on the rear drum rollers. check belt to make sure it is wound correcty around the idler pulley.
#3 Posted : Saturday, May 4, 2013 5:47:47 PM(UTC)
Did you replace the felt underpad and the glide or just the glide?
