My kitchenaid undercounter icemaker is not making ice. the model number is kuic18nnts0 I replaced the water fill sensor did not help. The ice maker fills with water the pump will start and circulate water over the cold plate for about 30 sec then drain all the water and start all over. It will not make ice.I did run a diagnostic test and it check out ok :confused: any help would be appreciated
