A friend gave me an old but serviceable oven to use in baking coatings onto metal parts. I have looked everywhere on it for a model number but can't find one. However, I suspect that all ovens are wired the same. This one has a shielded cable containing a white, a red, a black and a copper (ground) wire. Am I correct that ovens are hard-wired to 220V inside a box, rather than plugged onto an outlet; and that the connections are simply black to black, white to white, and so forth?
Thank you for any help you can provide.
Yes, most are hard wired. This sounds like a 4 wire hook up. So unless someone has messed with it, it is red to red , black to black, white to white and bare copper to frame/ground.
Will depend on what is at the electrical box which may be 3 wire in which case the wiring is different. |
THIS FORUM IS DEAD!!!!!!! |
