AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Reconnecting wires to the heating element and thermostat
I took off the heating element to test it and did not keep track of what wires were connected to it. There are two wires labeled H1 & H2, and two wires labeled HS1 & HS3. Which two go to the heating element?
See the attachment for the wiring diagram. |
THIS FORUM IS DEAD!!!!!!! |
This diagram is for a washer not the dryer. Do you have the wiring diagram for the LTE5243DZO dryer?
This is what comes up when I use the given model number re: a combo unit.
Lower half of the wiring diagram is the dryer. |
Dryer Repair
