The timer has the 2nd rinse setting, with off between first and second rinse on the dial, but no 2nd rinse select switch. I would like to get the second rinse to run all the time when on heavy wash. Looking at the wiring diagram and switch diagram, i may be able hot wire this connection. Which one is it? Looks like T-V color wire. Please help.
