jlesley
#1 Posted : Wednesday, May 1, 2013 5:10:11 AM(UTC)
jlesley
Have two of same oven. They both heat either to hot or not hot enough. Checked sensor and unable to get a reading on either one.
#2 Posted : Wednesday, May 1, 2013 5:55:53 AM(UTC)
Your model number is missing digits at the end.
Please check it.
Find your model number - AppliancePartsPros.com
[COLOR="Blue"]
Checked sensor and unable to get a reading on either one.[/COLOR]
Something is wrong with the above in that you get different results
I am not sure what you mean by "unable to get a reading"
Some people say 0 ohms is no reading. In this case the elements would come on full and just keep heating up.
Some people say infinite ohms is no reading. In this case the elements would not come on.
So I think yo measured the sensors incorrectly.
Did you short the meter leads together to be sure the meter was OK?
Did you use a high enough resistance scale? For instance if you use a 200 ohm scale then 1,000 ohms will show up as an open (infinite ohms). Use a 2.000 ohm meter scale.
http://www.applianceaid.com/electric-range-repair-topics.php
Check out 7, 8 , 20 and 21
Also how much too hot or not hot enough?
Most units will allow you to calibrate the oven plus or minus 35 degrees F.
This procedure is usually in the operators manual.
Whirlpool Gas Oven Irratic Oven temps (Oven Repair (including Ranges and Cooktops))
by Ann from KY 1/12/2013 7:29:55 PM(UTC)
