It seems to be leaking from the little box where the air comes from inside the middle of the Refrigertor. when I put my hand on it I reel it wet. It drips on to the bottom shelf that I just got from you feb 26. it then freezes on the shelf. So I guess it coming from the box and dripping down onto the shelf and freezes. the Refrigertor is working fine and so is the freezer both very cold. I see a vent inside the freezer could it be clogged or the people useing the freezer putting to much food over it. Or the one inside clogged. It was working find before they moved in. You were very helpful with my ice maker and I repaired it with the part I got from your help. Thank's for your help in this matter. TOM
:confused: Originally Posted by: Thomas A  It seems to be leaking from the little box where the air comes from inside the middle of the Refrigertor. when I put my hand on it I reel it wet. It drips on to the bottom shelf that I just got from you feb 26. it then freezes on the shelf. So I guess it coming from the box and dripping down onto the shelf and freezes. the Refrigertor is working fine and so is the freezer both very cold. I see a vent inside the freezer could it be clogged or the people useing the freezer putting to much food over it. Or the one inside clogged. It was working find before they moved in. You were very helpful with my ice maker and I repaired it with the part I got from your help. Thank's for your help in this matter. TOM
