2 Pages12>
rlmoore06
#1 Posted : Tuesday, April 30, 2013 6:39:12 AM(UTC)
rlmoore06
Re: Whirlpool DU1100XTPQ3. Couldn't find tech sheet where it was supposed to be. What I'm looking for are the push button sequences to run diagnostics on the components so I can try to narrow down my problem. Problem has to do with flashing light. Not sure if it is door latch, heating element, sensor or what....Rick
#2 Posted : Tuesday, April 30, 2013 7:38:18 AM(UTC)
Parts for Whirlpool DU1100XTPQ3 Dishwasher - AppliancePartsPros.com
See the attachment for the tech sheet
File Attachment(s):
DU1100.pdf (162kb) downloaded 43 time(s).
rlmoore06
#3 Posted : Tuesday, April 30, 2013 7:58:13 AM(UTC)
rlmoore06
Thanks much, denman....this should help....Rick
rlmoore06
#4 Posted : Wednesday, May 1, 2013 4:39:22 AM(UTC)
rlmoore06
Denman:
I ran the diagnostic sequence, and it completed without stopping....run took about 16 -17 mins. When I went to run a load through, it cut off at about the 8 min mark and the light started the 7 blink sequence again. Shortly after it cut off, i reached in and felt the heating element and it wasn't warm. I'm prepared to replace the element and the thermostat, but I want to be sure that those may be the only issues involved. This dishwasher is such a pain to get in and out from under the counter I'd like to have to only do it once......Rick
#5 Posted : Wednesday, May 1, 2013 5:17:06 AM(UTC)
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Check the high limit thermostat. It should be 0 ohms at room temperature.
Then check the heater it should be around 20 ohms.
Check that the door switch (upper right corner on the wiring diagram) is closed. It is in the heater circuit.
You may be able to fix it without pulling the unit.
This is how I would do it
Unplug or flip the breaker off.
Set the meter to it's most sensitive ohms setting usually 200 ohms.
Remove the kick plate.
Most dishwashers are hard wired using wire nuts.
Remove the one connecting the white wires so you can use that as a test point.
Now put the other meter lead to one side of the hi-limit. You should be able to reach it. Then check the other side of the high limit.
If both sides read about 20 ohms (heater resistance) then odds are you have a control problem. I would check the wires that come down from the control board to the high limit and heater first just to be sure they are OK. Also see below.
If one side reads 20 ohms and the other is infinite then odds are that the hi-limit is toast. Remove one wire from it and measure across it, it should be 0 ohms.
If both side measure infinite ohms then the problem is either a bad wire, a blown heater or a bad door switch.
One thing to note is that a bad door switch may be a mechanical latch problem re: the switch is not being closed when the door is closed.
If all OK
Then check the thermistor, see the tech sheet. It's resistance drops with temperature increase.
IF OK then check the wires from the parts back up to the control board.
If OK then odds are the control board is the problem.
rlmoore06
#6 Posted : Thursday, May 2, 2013 12:43:47 PM(UTC)
rlmoore06
Denman:
Got the meter, but I can't reach it from under the kick place. Going to have to pull the unit out on Sunday (hopefully), so I have the good part of the day to work on it...Is there anything else I should check (other than the high limit, heating element and door switch) while i have it out?....Rick
rlmoore06
#7 Posted : Sunday, May 5, 2013 8:46:48 AM(UTC)
rlmoore06
Just a side note as I get into this thing.....wife said that she ran the dishwasher on the pots and pans cycle last night and everything seemed to work fine including the heating element ("everything was pretty hot when cycle completed").....Rick
rlmoore06
#8 Posted : Sunday, May 5, 2013 10:52:17 AM(UTC)
rlmoore06
OK, the heating element is around 10.3 ohms and the high limit is about 0.3 ohms.....Rick
#9 Posted : Monday, May 6, 2013 1:59:08 AM(UTC)
Not a lucky day for you sounds like the unit may have gone intermittent on you OR perhaps a lucky day and it will continue to run.
You are sort of screwed trying to trouble shoot it if it is working OK.
Your readings look OK with one proviso, see below.
Could be that there was a control board problem and by removing power from the unit you reset it.
So here are possibilities if it starts acting up again.
1. Did you short the meter leads before starting your measurements to be sure 0.3 ohms is a real reading and not just a zero offset in the meter. Sometimes you can see a low resistance just because you cannot make perfect contact to the connector. But it also could also indicate a problem with the thermostat's contacts.
2. Did you notice any signs of overheating at any of the connections re: the wire insulation crinkled or discolored or a discolored connector. This would be an indicator of a bad connection which you may have corrected when working on the unit.
I will keep my fingers crossed that the unit keeps on working.
rlmoore06
#10 Posted : Monday, May 6, 2013 9:33:00 AM(UTC)
rlmoore06
Denman:
I checked the meter by shorting the leads and it jumped around a bit but didn't really settle on a reading. When the leads were separated, the meter read 1.
None of the wires show signs of overheating. I'll probably try putting the dishwasher back together and see if it runs OK. I also checked the switches and they read 0 when open and various numbers when closed. (hard to get a consistant reading).
I was wondering though, is there anyway to get the door to close tighter?
When I close the door and it latches, it seems a little loose and there is about 1/8th inch play when I press it tightly shut then let it go.....Rick
Need Tech Sheet for Kitchenaid Dishwaser (Dishwasher Repair)
by Guest 11/29/2021 9:40:05 AM(UTC)
Help! Tech sheet lost for Kitchenaid refrigerator (Refrigerator & Freezer Repair)
by DANDKB 4/24/2020 11:38:19 PM(UTC)
Kenmore Elite Dishwasher Tech Sheet needed (Dishwasher Repair)
by Recon2it 3/15/2019 3:06:42 PM(UTC)
Where does Kenmore usually hide its tech sheet? (Refrigerator & Freezer Repair)
by bluefitness 3/3/2019 5:16:57 PM(UTC)
Need whirlpool tech sheet (Dryer Repair)
by mmerritt@mtech1.com 1/30/2016 4:49:15 PM(UTC)
Tech Sheet Needed for Whirlpool Cabrio HE washer (Washer Repair)
by chefj 1/6/2016 9:26:32 AM(UTC)
Tech Sheet and Wiring Diagram (Refrigerator & Freezer Repair)
by Murff_Colum 12/1/2015 9:43:13 AM(UTC)
Tech sheet for maytag (Dishwasher Repair)
by pnkflyd3 10/14/2015 4:19:11 PM(UTC)
Schematic and tech sheet with diagnostic codes missing (Refrigerator & Freezer Repair)
by PeteClements 3/22/2015 7:15:13 AM(UTC)
Have wiring diagram, need tech sheet (Dishwasher Repair)
by redpyll 1/14/2015 10:26:00 PM(UTC)
Is tech sheet available for my Kitchenaid?? (Dishwasher Repair)
by deebickle 1/7/2015 11:15:57 AM(UTC)
Dishwasher Tech Sheet (Dryer Repair)
by jyama99 1/3/2015 10:09:19 AM(UTC)
Jenn-Air Convection oven buttons/find a tech sheet? (Oven Repair (including Ranges and Cooktops))
by Kat905 12/19/2014 8:33:22 AM(UTC)
help getting tech sheet (Washer Repair)
by johnt31313 7/24/2014 5:56:08 PM(UTC)
need tech sheet (Washer Repair)
by dlarvin 11/22/2013 11:26:51 AM(UTC)
2 Pages12>
