firemante
#1 Posted : Tuesday, April 21, 2009 1:03:07 PM(UTC)
firemante
looking for directions on how to change the hinges on this unit! :eek: I have removed the top and bottom screws, however i can not get the hinge unit to slide out. Any help ??
#2 Posted : Wednesday, April 22, 2009 2:14:30 AM(UTC)
This may help
http://www.servicematters.com/m...ibrary/docs/D231_1R6.pdf
You may have to give them a bit of a hit as they may be stuck to the frame.
firemante
#3 Posted : Wednesday, April 22, 2009 5:06:06 PM(UTC)
firemante
that did the trick, all i needed to do was lock the hinge in the open position and the old slid out and the new slid right in..... THANKS FOR THE HELP !! :D
