caesar.2009
#1 Posted : Tuesday, April 23, 2013 5:04:45 PM(UTC)
caesar.2009
hello, I checked motor that drains water from machine seems good has compression, cleaned hoses looks good, the water keeps filling after cycle is done I thought the motor was broke but runs fine.
sidfink43
#2 Posted : Thursday, April 25, 2013 3:56:00 PM(UTC)
sidfink43
Well this a new one for me, and I thought I had seen every problem with the Duet models.
If you look under the top there should be tech notes that will show you how to put the machine into a diagnostic mode. If you cannot do so the problem may be in the main control unit. Also focus on the water valve assembly.
Wish I could be more specific, but as I said, this is unusual.
caesar.2009
#3 Posted : Friday, April 26, 2013 8:46:57 AM(UTC)
caesar.2009
hey thanks for your reply good help it is unusual how do i get to diagnostic button or maybe manual, any help is greatly appreciated
sidfink43
#4 Posted: : Friday, April 26, 2013 11:03:58 AM(UTC)
sidfink43
At the back of the washer are three screws that hold the top on. Take them out and the top will slide off and there should be tech notes right there.
Good luck, hope this helps.
#5 Posted : Friday, April 26, 2013 11:40:50 AM(UTC)
In case it is not there see the attachment.
File Attachment(s):
GHW9400.pdf (261kb) downloaded 9 time(s).
