justin954
#1 Posted : Friday, April 26, 2013 7:25:12 AM(UTC)
justin954
Washer is ONLY 13 Months old! I did not take an extended warranty like a fool!
It washes correctly, spins, etc. When it is in the spin / drain cycle is leaks from the front right bottom. I attached a photo. Any help is appreciated, any ideas as to what this could be? IF you see in that photo the small metal lip hanging is where the water is coming from. THANKS GUYS!
UserPostedImage
fairbank56
#2 Posted : Friday, April 26, 2013 8:18:49 AM(UTC)
fairbank56
Groups: Expert
Take the front panel off so you can determine where the leak is coming from. Insert a putty knife into the top groove of the front panel in line with the lid opening on each side to release the clips while pulling slightly on the panel. Tilt the panel outward and lift off from the cabinet. You can run the washer with the panel off. Pump and drain hoses are on lower right side. Use a flashlight to determine source of leak.
Eric
