Michele Rizzetta
#1 Posted : Tuesday, April 21, 2009 5:33:33 PM(UTC)
Michele Rizzetta
When the dishwasher get to the last minute of the cycle it does not stop the water keeps running inside, Do i need to replace the control board.. this is the 2end time this happend to this dishwasher. it is very expensive for a repairman to come out and charge for the parts and labor and the service call if i can do this myself I will, thanks Michele
Michele Rizzetta
#2 Posted : Tuesday, April 21, 2009 5:37:39 PM(UTC)
Michele Rizzetta
I have a Bosch Dishwasherm when it get down to the last minute in the cycle it keeps running water, it does not stop to dry the dishes,Do I have to replace the control panel this is the 2end time this happend to this dishwasher so there is water in the bottom of the dishwasher..see my info on the message above,,I hope you can help me to do this myself..thanks Michele
#3 Posted : Wednesday, April 22, 2009 3:46:53 PM(UTC)
Looks like the problem is a bad control module and the correction is to replace it. If you know how to handle a simple tools then this job is not going to be very difficult. You can find the instructions attached to this reply.
- The part number for the control module is AP2802870
Here are the breakdown diagrams and Replacement parts for BOSCH SHU6805 UC/12 (FD 8003-) | AppliancePartsPros.com
File Attachment(s):
How to replace control module.doc (25kb) downloaded 13 time(s).
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
