AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Frig still Freezes after putting in Diffuser part recommendation
Took your recommendation and put in Diffuser but Fridge still Freezes. I want to fix fridge what is my next option to fix this problem. My email for answer is ronmims99@bellsouth.net. Thanks Look forward to your suggestions, comments, and instructions.
Gene, thanks for reply dont have the capability to do a diagnostic check, but if you think replacing thermistor, I will give it a try, lot cheaper than other choices. Thanks again. Ron
Gene, thanks for reply will probably replace the thermistor since the other parts are so high. What do you think? Ron
Hi Ron, A bad thermistor is only one of possibilities. You can give it a try but what are you going to do if it would not fix the problem? - The thermistor Part number: 2188819
Gene, I guess because I dont know that if the thermistor does not fix will have go to next part which is some kind of board? What do you think? Thanks Ron
Ron,
I did not understand why you can not do this test. It's pretty simple.
Hey Gene, I dont know how to do test, but I can change parts. HA. Do you think that Thermistor would fix problem??Thanks Ron
Originally Posted by: wron  ...I dont know how to do test... Hi Ron, It's pretty simple. Just click on the link I posted, open the file, read it and follow the instructions. Gene.
Help, Help, Replaced both the Diffuser and thermistor and fridge still is freezing around 20 below zero. What are my next and best option of this refrigerator Model KSRS25CSMS01. Thanks and look forward to suggestions and comments. Ron
