Paloco
#1 Posted : Tuesday, April 23, 2013 12:04:14 PM(UTC)
Paloco
Hello,
The vent fan in my NuTone range hood runs well on high-speed but takes about 5 minutes to get up to the correct rpms on low speed. Troubleshooting efforts I have tried are oiling the fan motor and letting the fan run for 5-10 minutes on low setting to ensure that it is completely lubricated. Please advise.
NuTone Range Hood ID: V19D66W (the D may be an N)
Information on Fan Casing:
Model ID: AA2M054F#
RPM 1550; #21939; LR12645; 115v; cycle 60; amps .87;
serial # 12Z52126R
scott5495
#2 Posted : Tuesday, April 23, 2013 3:19:19 PM(UTC)
scott5495
on high, the fan motor recieves 120 volts. on low the voltage drops in order to slow the fan down. make sure the grease filter is clean and the damper is opening. sounds like a bad motor otherwise.
Paloco
#3 Posted : Tuesday, April 23, 2013 4:56:26 PM(UTC)
Paloco
Scott,
Thank you for your response. Please clarify what the grease filter is. There is a stainless steel filter--what I would call an air filter--which has been cleaned. Also, the damper does work--I can hear it open and close.
Please tell me if I can still obtain the same fan motor, or let me know of another that would work with my range hood's bracket holes. In addition, any other information that I may need to have in selecting a new motor--if that is the case--will be appreciated.
Paloco
scott5495
#4 Posted : Tuesday, April 23, 2013 5:08:15 PM(UTC)
scott5495
the air filter and grease filter are the same part. it is a lot easier to replace the fan motor with the original. get the model no. off the hood and call cashwells appliance parts at 1-800-277-1220. they can help on the part, original or replacement.
Paloco
#5 Posted : Tuesday, April 23, 2013 5:14:36 PM(UTC)
Paloco
Scott,
Thank you for your assistance and time. I appreciate it!
Paloco
MarcPierre
#6 Posted : Monday, September 30, 2013 3:19:03 AM(UTC)
MarcPierre
I think your issue has been solved and the vent fan is working well. Can you please share the steps that you used to troubleshoot this problem?
__________________
broan range hoods
Paloco
#7 Posted : Monday, September 30, 2013 10:19:14 AM(UTC)
Paloco
I solved the issue by taking the fan motor to a local repair shop. They took it apart, cleaned, and lubricated it. It works just fine now. Just
goes to show that it is sometimes worth repairing things instead of
replacing them. I saved myself a great deal of money by doing so.
