Calyn
#1 Posted : Sunday, April 21, 2013 9:17:55 AM(UTC)
Calyn
I love this dryer, it's been a champ. Recently it's started to squeak loudly around mid-cycle until the cycle finishes. When I put in a new load right afterwards, it often stops until mid-cycle once again.
I've been reading responses that it could be a rear bearing. Once again I call upon your expertise so I can get the parts ordered and fix it!
Thanks so much!
scott5495
#2 Posted : Sunday, April 21, 2013 12:45:48 PM(UTC)
scott5495
ge has had a problem in this area. it is the ground strap that is squealing and ge has a replacement part no. we1m544 strap, comes with instructions. while i had it apart i would go ahead and replace the sleeve bearing part no. we25m40. both parts are inexpensive.
