Most likely the problem is a bad water level switch or a broken air pressure hose. The model number you posted does not come up. Verify and repost it.
thanks gene #is pav2360aww
thanks gene the model # is pav2360aww
Nick,
I found that for the correct part number the serial number of the washer also needed.
