2 Pages<12
moody9207
#11 Posted : Thursday, April 18, 2013 7:45:28 PM(UTC)
moody9207
Hi Simon, after repeated attempts to properly seat the drum with the ballhitch attached, I decided to remove it and check some measurements and I think now that the drum / ballhitch is seating okay, but perhaps I did not apply enough grease. Does a certain level of grease help to hold the drum more firmly? Perhaps the grease acts like packing material.
I recall when I first reattached the drum to the old ballhitch, the drum was certainly held in place, despite finding that the old plastic bearing piece was very much worn away.
I took a picture of the ballhitch in place. Most of the grease I applied has been removed as a result of my repeated attempts so I will apply more. The ballhitch right now moves around enough to clearly tell me that the weight of the drum would certainly pull it down in front.
Any other suggestions for me to solve this?
Also, thanks for your patience with me and my questions.
moody9207 attached the following image(s):
Simon / APP Team
#12 Posted : Friday, April 19, 2013 1:06:23 PM(UTC)
Simon / APP Team
Groups: APP Team
Sorry, never had such a problem.
I always attach the ballhitch to the drum and insert it in to the bearing.
Simon.
squealing noise when dryer full and running (Dryer Repair)
by MissFitFL 9/11/2016 11:17:49 AM(UTC)
squealing noise from frigidaire front loader (Washer Repair)
by jimmygabe 11/17/2014 2:20:04 PM(UTC)
Maytag Performa loud squealing noise (Washer Repair)
by jeneerik 4/27/2013 12:49:18 PM(UTC)
My GE Dryer is making a squealing noise (Dryer Repair)
by John nut 2/1/2013 8:31:37 AM(UTC)
Agitator not working, squealing noise (Washer Repair)
by lderubeis 3/17/2012 11:34:59 PM(UTC)
Squealing noise after changing Motor Coupler (Washer Repair)
by DanPizano 4/10/2011 11:06:41 AM(UTC)
Washer Making Squealing Noises (Washer Repair)
by CGLANK 1/3/2011 2:49:01 PM(UTC)
dryer makes continuous loud squealing noise (Dryer Repair)
by gfroman 8/11/2010 7:53:34 AM(UTC)
Washer squealing noise (Washer Repair)
by Dave M. 6/6/2010 1:53:11 PM(UTC)
Maytag Dryer makes an awful squealing noise (Dryer Repair)
by cfoley 5/18/2009 12:54:40 PM(UTC)
Squealing Noise (Dryer Repair)
by mjmorizio@earthlink.net 12/3/2008 5:40:07 PM(UTC)
High pitched squealing noise (Dryer Repair)
by b428337 10/3/2008 8:09:42 AM(UTC)
Squealing noise from Signature 2000 electric dryer (Dryer Repair)
by saumila 2/13/2008 4:14:16 PM(UTC)
2 Pages<12
