My admiral washing machine will not spin sometimes, when this happens there is a loud solenoid click but the spin cycle and pump do not start, the timer can still be heard ticking away. After switching the machine off for a few minutes the spin cycle and pump usually start to work. This morning the same happened again, after switching the machine off for a few minutes and then back on, and putting it on the spin cycle the water pump stated but the machine would not spin immediately, it started slowly at first then got faster and faster. The door switch has been checked and is working properly. Please HELP!!!!
Can you please post your model number. The number you have posted is not a model number. Look for the model number on the back of the machine, or inside of the lid.
I am sorry, but that is not a complete model number. The model number should be a 6 to 14 character listing. If you cannot find it look at the how to find model number section on this site.
Sorry wrong number, I checked the number myself this time and the correct model number is 7010LOAUS.
Sorry, I cannot get this number to come up as a valid model number. Maybe someone else on the forum can help you.
Good luck
