lewisource
#1 Posted : Tuesday, April 21, 2009 7:55:01 AM(UTC)
lewisource
My system has worked fine but what I am running into is the ice maker makes ice fine but won't dispense it. The auger is spinning but nothing is dropping. I have checked the chute through the door and it's not jammed but I do continually get 1-2 cubes logged in the metal piece just about the chute and I believe that is what is causing my problem. How do I prevent this from happening?
#2 Posted : Tuesday, April 21, 2009 10:50:51 AM(UTC)
Does the door in the chute open completely?
What does it do if you choose crashed ice?
lewisource
#3 Posted : Tuesday, April 21, 2009 6:13:29 PM(UTC)
lewisource
The door in the chute does open but I have had times where ice would get frozen in the chute and I had to break it up.
If I chose crushed ice, I get the same result, no ice. You can hear the auger turning and a loud thumping noice but no ice?
#4 Posted : Wednesday, April 22, 2009 2:04:08 PM(UTC)
Does the door in chute close completely? If it's not then a warm air can come through causing a condensation and frost in the ice crusher.
lewisource
#5 Posted : Thursday, April 23, 2009 1:34:50 PM(UTC)
lewisource
It appears to be completely closed, is there a way to tell for sure?
#6 Posted : Thursday, April 23, 2009 3:02:50 PM(UTC)
Push the ice release to open it and then watch how it will close.
ice won't dispense (Refrigerator & Freezer Repair)
by ekirby19mx 6/6/2013 6:29:08 AM(UTC)
Ice won't dispense (Refrigerator & Freezer Repair)
by mattpaul3 9/3/2012 4:22:41 PM(UTC)
by palmettogolf 5/31/2009 5:41:44 PM(UTC)
Water and ice won't dispense from GE fridge. Can anyone help? (Refrigerator & Freezer Repair)
by Steph1079 3/6/2009 5:37:50 AM(UTC)
by dolfanjhn 11/19/2008 7:53:37 AM(UTC)
