montynv
#1 Posted : Wednesday, April 17, 2013 7:16:22 PM(UTC)
montynv
I was cleaning out my freezer for about 10 minutes and when i was done i shut the lid and freezer kicked on and sounded fine. I then turned the dial colder and heard a click sound from the dial and freezer did not run after that. The light is on, so the outlet is working, but the compressor stopped running. It hasn't turned on since. I turned the dial all the way both ways thinking it was turned off but no luck. I left the dial in the middle but never turned on. The freezer was working prior to that. Will I be able to fix it or should I call the company directly?
montynv
#2 Posted : Wednesday, April 17, 2013 7:18:51 PM(UTC)
montynv
this is frigidaire chest freezer. are you sure it does not make a compressor noise when lid is shut. I swore ive heard it before. what do you make out of the click sound
#3 Posted : Thursday, April 18, 2013 3:11:49 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
I cannot say if you should call in a pro depends on your experience with electrical devices.
Also you will probably need a multimeter to diagnose the problem.
