I have a 2003 Frigidaire side by side that is having problems. About a week ago I noticed the items in the freezer were cold, but not frozen. Fridge side working fine. After a couple days in denial, we threw out our freezer food and I called a repair man. After about 20 minutes of general looking he concluded that I had a freon leak brought on by dust/hair insulating the coils and getting them hot enough to melt solder joints. Since unit is 10 years old, recommended I just replace unit instead of repairing coils. About this time the fridge started to get warmer as well. Figured time for a new fridge.
But to save fridge items prior to new purchase, I shifted everything from fridge to freezer (from 45-50 degrees to perfect 32-35 degrees). Its now been another 2 days and my freezer (on max cold) is maintaining a nice 32 degrees and my fridge (also max cold) is now at 40 degrees. Question is, if I have a freon leak why am I still maintaining these temperatures....or could it be something else?
Please advise, need to repair or replace soon.
Groups: APP Team
Hi.
Remove the rear cover panel inside the freezer and check the frost pattern on the evaporator. If it's only partially covered or iced up in one corner - it's a sealed system problem and $$$. If it's completely blocked with snow - it's a defrost system problem and should be repaired.
For more help if it's a defrost, please provide the complete model number.
Simon.
Thanks for prompt response. I wondered if it was a defrost problem (freezer stuck in defrost mode). I will empty contents and remove panel to check evaporator. Repair man only removed bottom plate on back of unit.
can a repair person effectively assess a freon leak from only removing rear panel and looking at compressor, condensor and condensor fan?
Groups: APP Team
Yes. The experienced repair person may come to this conclusion just by checking the compressor's and condensor's temperature, and amperage draw.
Simon.
