Petee
#1 Posted : Monday, April 15, 2013 1:59:42 PM(UTC)
Petee
The water/ice dispenser of my fridge not dispense ice from the ice bin. The water part is fine and it has no problem to dispense water. When I push the latch, there is no humming sound. Would this be the motor issue?
Thanks for any help.
Simon / APP Team
#2 Posted : Monday, April 15, 2013 2:31:17 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the ice door opens when you push the lever? If it doesn't, then most likely it's a broken micro switch or bracket.If it does - bad dispenser motor.
You also should check if the wires down at the freezer bottom hinge are OK.
Here are the breakdown diagrams and http://cdn.appliancepart...ms/dcache/29289596_2.gif
Post the results.
Simon.
