I have a Frigidaire refrigerator(model#GLRT13TEW4). The freezer gets cold, but after a while, several hours maybe, everything in the freezer will begin to melt. I replaced the defrost thermostat and the defrost timer. It is still doing the same thing. I noticed that the freezer will begin to lose cold until items inside melt. At that point I give it a whack with my hand, right where the defrost timer is located inside the fridge, then I hear what i assume is the compressor kick on and the freezer starts blowing cold immediately. Help
Instead of giving it a thump move the main temperature control back and forth. It could be that it's contacts are sticking open. |
THIS FORUM IS DEAD!!!!!!! |
