iceskaters
#1 Posted : Friday, April 12, 2013 11:08:13 AM(UTC)
iceskaters
My condenser fan won't turn on by itself causing the seals on the freezer/fridge doors to be warm to the touch and the inside back/bottom of the fridge to be hot. If you gently spin the fan it runs, cools the fridge and then shuts off automatically. When the refrigerator again starts to run the fan will not start up on it's own and the fridge will run continuously. Inside both freezer and fridge are fine, just the outside gets hot to the touch. Once I spin the fan gently it again works fine. Any ideas why the fan seems to work but won't start up on it's own? I even just lightly oiled the fan just in case it was dust. Runs quietly when working.
#2 Posted : Friday, April 12, 2013 4:38:39 PM(UTC)
Hello,
The fan motor has to be replaced. No doubt about it.
- The condenser fan motor Part number: 61005323
iceskaters
#3 Posted : Friday, April 12, 2013 5:22:22 PM(UTC)
iceskaters
Thank you Gene, I thought that might be the case, wanted to be certain before I ordered the part. Will get it done early next week. I appreciate the quick reply.
Lori
#4 Posted : Friday, April 12, 2013 7:48:12 PM(UTC)
You are welcome Lori. You may want to order as soon as possible because this faulty motor can cause a damage to the compressor.
Keep us posted.
iceskaters
#5 Posted : Tuesday, April 23, 2013 7:44:00 PM(UTC)
iceskaters
Received the condenser fan motor, installed it this morning and now it works great!!!
#6 Posted : Wednesday, April 24, 2013 12:44:21 PM(UTC)
Lori,
I'm glad it's up and running.
Gary77
#7 Posted : Friday, August 28, 2015 2:22:11 PM(UTC)
Gary77
Gene, I see that you posted to this thread back in 2013.
Are you still watching this website?
Maybe you can help me with mine.
Gary
Guest (6)
