evdokareal
#1 Posted : Monday, April 8, 2013 7:28:24 PM(UTC)
evdokareal
I have located and tested the defrost thermostat and there is no continuity. I have not tested the thermistor in the freezer compartment. Is this necessary?
#2 Posted : Tuesday, April 9, 2013 6:28:51 AM(UTC)
Parts for Whirlpool GB2SHTXTT00 Refrigerator - AppliancePartsPros.com
As long as the only problem you have is a defost problem and you checked the defrost thermostat when it was frozen then it should be the only part you need,
