CapeCoddah
#1 Posted : Monday, April 8, 2013 10:37:59 AM(UTC)
CapeCoddah
The customer's complaint was warm fridge, cold freezer (this is a bottom-freezer model, with icemaker. It has digital touch controls located in the French-door refrigerator section). I jumped to conclusions and replaced the motorized damper which regulates fridge temperature in this model; I then discovered that the evaporator was completely iced up. After defrosting it manually w/heat gun, I checked the heater resistance; it's o-k. Further research revealed that there is no traditional defrost clock; it uses a module which I believe is part of the digital temp. control setup. I should note that the unit was subjected to multiple power failure events due to a prolonged northeast storm (happens a lot here on Cape Cod). What are the chances that the module is defective, as against the likelihood of a defrost thermostat gone bad? The thermostat is hard to check once the unit is defrosted to the point where you can get to the connections....
#2 Posted : Tuesday, April 9, 2013 6:15:05 AM(UTC)
Parts for Amana ABL1922FES - AppliancePartsPros.com
Your model number seems to be missing the last digit when it comes to getting a tech sheet. The following is for a FES3 but may also apply to other units in the series.
See the attachment.
Try forcing a defrost.
If the defrost heater comes on then I would replace the board.
the defrost thermostat can be checked by holding it's metal faceonto an ice cube to get it into a frozen stat.
Also if it is deformed/bulged, replace it even if it measures OK.
File Attachment(s):
ABL1922.pdf (390kb) downloaded 19 time(s).
CapeCoddah
#3 Posted : Thursday, April 11, 2013 12:56:23 AM(UTC)
CapeCoddah
Originally Posted by: denman Go to Quoted Post
See the attachment.
Thank you, denman! I've printed and saved the .pdf you sent, and will try forcing a defrost. Also, the sheet gives the protocol for checking the defrost thermostat using the keypad; I'll try that too.
