About ten minutes into the wash cycle, as soon as the detergent dispenser opens, the cycle is canceled and the dishwasher drains and shuts off.
Cdraper
I have the same model and the same problem. Did you find a solution?
It was still under warranty and we were able to have it repaired. The technician replaced the control board and the replacement part is W10395153. Here's a link to a an Amana bulletin regarding this problem. Hope that helps!
