imageshift
#1 Posted : Tuesday, April 2, 2013 8:49:27 AM(UTC)
imageshift
Hi - My washer started having a slow spin cycle problem. Everything else works great. Strong agitate cycle... drains perfect... Just a slow spin cycle. I tried the unplug for a minute then lift the lid 6 times reset thing.
Through all my trials and errors I have got it to spin at full speed... maybe 4 times out of 10. It spun out three loads in a row yesterday then failed to spin hard on load 4 and 5.
lite or heavy loads don't seem to make a difference.
Ant ideas? Thanks >Robert
sidfink43
#2 Posted : Thursday, April 4, 2013 5:01:30 PM(UTC)
sidfink43
Take off the front cover by inserting a thin screw driver in the gap between the top and the front near the edges to release the clips that hold the front to the cabinet.
Then check to see if something is caught between the tub and basket. If not, observe the machine spinning and see if you can determine anything. If not, use this guide
HydroWave GE Washer Repair Guide
to trouble shoot. The first thing to do is the reset it, sometimes that is all that is needed.
