nicvoi
#1 Posted : Sunday, March 31, 2013 4:37:15 PM(UTC)
nicvoi
Hi, my washer not working in the spin cycle. it washes and agitates, it even drains most of the water. but it doesnt spin the water out of the clothes. I did some research and thought it was the clutch, so i replaced that. Not the problem. help!!
sidfink43
#2 Posted : Tuesday, April 2, 2013 4:06:06 PM(UTC)
sidfink43
Operate it with the cabinet off by bypassing the lid switch and see how fast it spins when there is a full load of clothes in there.
If it is not spinning fast and you are sure the clutch is okay, the problem may be the brakes are hanging up. If it spins fast enough but the clothes are still too wet there may be a problem in the internal or external drain hoses.
Roper Washer Wont Spin (Washer Repair)
by Jason LaPort 12/29/2013 1:53:17 PM(UTC)
roper washer wont spin (Washer Repair)
by nicvoi 3/31/2013 5:02:49 PM(UTC)
roper washer wont spin or drain water (Washer Repair)
by michalek 3/28/2011 6:59:22 PM(UTC)
Roper washer wont spin and wont empty (Washer Repair)
by jgirl14572 10/10/2009 6:20:33 AM(UTC)
